Old 12-10-2012, 05:59 PM   #6
thstone
To raise the front: Lift at the rear jacking point until you can get the jackstand under the front jacking point. Then do the other side the same way.
To raise the rear: Lift from the rear end under the car at the rear suspension mounting point until you can get a jackstand under the rear jacking point. Then do the other side the same way.
