Old 12-06-2012, 08:16 PM   #5
Meir
1999 base
Meir's Avatar
BTW.
The fuse is 15 amp,and bucking up the alarm,DME and tiptronic mudule (if your car is tip).
Not sure what is the power consumption of your setup, but if it was me, I would use the wire to trigger a 30 amp relay. You can feed the relay from the 40 amp SAP maxi fuse located on the bottom of the realay panel.
