It's probably the horn unit itself... but check your battery voltage as well. If it's too low i've seen a few not work. The horn is behind the front bumper to the inside of the rad (right side)... just plug a v-meter into the connector off the back of the horn and see if you get 12V when someone pushes on the horn in the car. It's a bit of a pain to get at as you pretty much have to pull the front bumper skirt... Could also be the relay going.... (Link to removing front Bumper... pretty good video from youtube http://www.youtube.com/watch?v=Um-h2aUJHY4)
Just some idea's...
H
Previously owned:
