Old 12-01-2012, 10:33 PM   #1
jb92563
jb92563's Avatar
Another First Auto-X & Tire pres questions
Did my first Autocross recently, it was blast!.
The instuctor mentioned that the rear tires were not "Locking Up" and said I might want to adjust the tire pressure.
We did not get a chance to make adjustments so i never found out how.
Any guidlines on how to adjust tire pressures when they could use some tweaking to get better perfomance?
I was running 32psi front and 36psi rear on Hankook V12's with 215mm wide front and 265mm wide in the rear.
Seems my rears where breaking away a bit too early so I could not take full advantage of my manueverabilty and speed in the curves and had to slow up too much.
I guess I need a bigger contact patch in the rear to help it stay attached to the ground.....more or less psi?
