11-24-2012, 04:51 AM
#28
1999 base
Originally Posted by navyc130fe
Be careful with the Loctite on the oil pan. If you put too much on it and it squeezes off inside the sump it can get sucked up into the engine, you will blow the motor. Also, make sure you torque the nuts down according to specs.
Advise taken.
Thanks.
