Old 11-22-2012, 05:39 AM   #66
Meir
1999 base
Meir's Avatar
Originally Posted by Gorthaur View Post
Hey guys, sorry for posing this question in this topic but I think we should consider what I came through after disconnecting the battery (even though we actually don't know whether the problem was related to bad fuel or the cluster job).
I'm going to replace the window regulator in the next weeks. Am I supposed to disconnect the battery (since I'll have to disconnect the airbag as well)? Can I do the whole job without touching the battery?
As far as I know, I should not turn ignition on with the airbag disconnected in order to prevent the correspondent light to come on on the cluster, is this right?
Thanks for your help, cheers.
G.
i disconnect the battery almost every time i work on the car. never had issues.
if disconnecting the airbag (i.e. steering wheel, door panels, seats), wait at least 15 minutes between battery disconnect, to airbag disconnect.
the reason for that is, the airbag system includes capacitors that keep the system alive, even if the battery is damaged (like in an accident for example).
just make sure when you disconnect the battery, that the ignition is off. in fact, better if you keep the key in your pocket this time
in some cases, when the battery was disconnected for a long time, the RPM in idle are not stable at firs star up.
you need to drive the car for a wail, so the ECU and the MAF sensor can synchronize.
