Old 11-19-2012, 05:00 AM   #2
Jaxonalden
Jaxonalden's Avatar
Spray WD-40 at all exposed bearing areas. You've obviously had the front engine cover off, with it off and the engine running, shoot a squirt at the base of the rotating shafts. I think you'll find the squeak.
If you do find it, you might want to go back with white lithium grease for a more permanent solution.
