11-11-2012, 08:09 AM
#11
Originally Posted by Meir
The OBDII connector is a standard.
The plug itself is the same in all vehicles from 96 and up.
With that said, the bracket of the OBDII connector can be different in it's mooting configuration. As far as I know, there are 4 types.
The "regular" most common comes in Japanese and European cars. has two clips on the sides to hold in place.
GM stile 1: the bracket has holes, so it is mounted with screws instead of clips.
GM stile 2: the bracket has rails. Mostly common with Pontiac cars.
And the German style. Has clips on bottom and top. Only comes in BMW, mercedes, Porsche, Audi and VW.
If you need one send me a PM. I might be able to help.
Just for reference, the pinout on all styles is the same.
Thanks Meir. The pins are much thinner on the Dura. than on the HUD so they mate up nicely in the 986. The HUD do not want to fully seat. I will check out the mounting styles.
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
