11-09-2012, 12:33 PM
#4
1999 base
Originally Posted by Kenny Boxster
Hello Meir,
It is not a bad idea to order the highlighted items. As for the pilot bearing, it was already included in my Sachs clutch kit, so you may end up with two of the same part. My kit, however, was for the 2.7L. I changed my clutch with just the Sachs kit, new pressure plate bolts, and clutch alignment tool. My kit came with a clutch disc, pressure plate, throw out bearing, pilot bearing, and special spline lubricant.
Hi Kenny.
i have the Sachs kit in hand, and it includes everything you mentioned accept the pilot bearing. pilot bearing is 18.95$ so it stays in the list
thanks.
