Thread: winter project
Old 11-09-2012, 08:36 AM   #1
Meir
1999 base
Meir's Avatar
winter project
Hello guys.
I’m preparing for my “winter project”, and right now I’m in the stage of collecting the needed parts.
My car is 2001S with 77K.
The plan is doing the following:
1. Fuel system flush (got Techron)
2. Drain oil and coolant (got washers for both drain plugs).
3. Fix a small leak from oil pan (got Loctite 5900).
4. Replacing fuel filter. (got filter)
5. Replacing front engine mount (got the mount)
6. Removing transmission.
7. Replace O-Ring on oil cooler (got the O-rings).
8. Replacing AOS with all pipes and O-Rings including oil filler tube (got all parts of AOS system and tube).
9. Replacing coolant tank (got tank).
10. Replacing IMS bearing (will order once transmission is off the car, and I will know which one I need)
11. Replacing RMS, transmission shaft seal. (need to order)
12. Replace flywheel if needed.
13. Cutch kit (got disk, pressure plate and release bearing)
Dose the order of execution makes sense?
Also need to order:
For the clutch replacement, I was wondering if the highlighted parts are necessary/ recommended to be replaced, and is there an alternative to the highly priced grease.
Will appreciate your opinion if I’m missing any parts (Or am I about to order parts that I don’t necessarily need), or if there are other thing to do “while in there”.
Thanks in advance.
Meir.
