Yes, you are pointing at the stabilizer bar or anti-sway bar. The bushing to the left of where your finger is pointing should hold the bar firm and not have any play vertically or left/right. Its ok if the bar rotates in the bushing and its ok if there is some slight movement into and away from the car in the same direction as your finger is pointing (axially).
