Old 10-25-2012, 01:10 PM   #5
thstone
Originally Posted by Bala View Post
I have a typical water pump bearing/pulley kind of noise. It is affected by change in RPM. I removed the belt and it is still tied to RPM. I use a hose to my ear and it seems to be coming just around the crank pulley but not 100% sure. Any ideas whether it could be the water pump? I'm not sure if it still is the original pump and the car has 92k miles. I'm swapping the engine mount and would liek to get this addressed if it is water pump, at the same time.
If you removed the belt, then the water pump, a/c compressor, power steering pump, idler pulley, and tensioner pulley are all ruled out because they all run off of the belt.
