Old 10-25-2012, 09:56 AM   #22
Meir
1999 base
Meir's Avatar
very nice tony.
i'm thinking about doing something similar, but using mini relays.
using the relays will not require any resistor if using LED bulbs.
on top of that, if the running lights are on, the "blinker command" will basically turn them off and on in the blinker pattern.
if the running lights are off, the "blinker command" will turn the lights on and off according to blinker pattern.
this setup is more complicated and will require running a line to the blinker fuse inside the car.
