When removing the roll bar padding it is best to use a flat head screwdriver, make sure you put a few layers on electrical tape over the blade potion so you do not scuff your roll bar paint. Watch out for those little clips…if you have a black interior they are hard to spot when they come out. Sometimes the plastic clips end up on the padding side too. Just pay attention when doing it and you'll be fine.
There are 3 clips on one roll bar hoop and two in the middle. I start by popping the bottom of the hoops, the second clip is in the middle, with two undone it is easy to see the third.
Much more simple than it sounds….don't forget the tape!
