10-24-2012, 11:47 PM
#5
Originally Posted by tony_fury
Can I suggest you check the light electrical socket in the fender.
There is a slider on the mount of the electrical connector that sometimes works loose.
If loose, it may not be making a good solid connection..
It could be you are not getting a sure fit when sliding the light into the fender.
Simple check to do..
T
Thank you will check.
