Old 10-24-2012, 12:51 PM   #7
Meir
1999 base
Meir's Avatar
Originally Posted by boxster View Post
I read about pedro's, but now i decided to just get one ready and replacing it.
"Meir", do you know which one I should get exactly from the 997 or cayman? and where do i get the silicon reducers?
thanks
TRK is much more knowledgeable then me, and most of the things i know about it, is from the tread he posted.
http://986forum.com/forums/general-discussions/31693-maf-throttle-body-diameter.html
this is the list of parts you will need:
one $42.43 997 110 416 03 997 plenum
two $ 3.05 999 512 539 01 hose clamp (for the larger plenum)
four $ 0.27 900 385 025 04 bolt (larger throttle body requires shorter bolts)
four $ 0.15 N 011 524 27 washer (for above)
one $ 5.49 997 110 319 00 throttle body gasket
as far as i understand, 996,997,and Cayman S, all have the same TB.
silicon reducers i got from here:
Intake Pipe Reducer
i also took TRK advice and ordered this:
Silicone Joiner 90 Degree Bend Reducer Elbow Hose 76mm 83mm 3" 3 25" 3 1 4" | eBay
i didn't installed it yet (all of it), since i'm still on the fence.
i think about getting the plenum and the ECU flash from Pedro.
need to decide what headers i'm going to put, first.
