The roll bar padding is removable. Use a screwdriver or similar tool to carefully pry it off. Pops back on.
The hoops are part of the roll bar itself. The entire assembly can be removed. Just follow down to the four mounting points and unbolt. You will have to remove some of the interior parts to get access.
