Originally Posted by poan
Hi
were do I find the transaxle?
And howto lubricate a transaxle?
P-O
The Boxster has a "transaxle" which is the transmission and the differential merged into a single unit. Hence, there is no traditional drive shaft (between the tranmission and the differential). The transaxle is lubricated internally by gear oil.
The transaxle oil can be topped up or replaced as described here: Pelican Technical Article: Boxster Differential / Manual Boxster Transmission Fluid Change - 986 / 987
