Old 10-17-2012, 04:30 PM   #1
brian325is
Use the instructions for roof installation on Mikes website. Basically you will remove the weatherstrip and rail above the side window and then unscew the metal roof bracket. You may have to take off one side on the front window weatherstrip. The top fabric is glued to the bracket and you will have to peel it back and re-glue afterwards. The cable attaches to a spring attached to the bracket
brian325is is offline   Reply With Quote
