Old 10-11-2012, 01:04 PM   #11
Meir
1999 base
Meir's Avatar
Originally Posted by jaykay View Post
Thanks. Yes shifter cables and lines are in different spots; maybe I can zip tie my cables away from the AC stuff.
So I take it an AC shop can evacuate and fill the system from the valve in the frunk.
yes.
[/QUOTE]I just have figure out how this line can come out[/QUOTE]
i would start by disconnecting it from the compressor and from the bottom line, and try to pull it out thru the to engine cover.
it dose look a little bit crowded in there, so you might have to move some other parts a side.
you will definitely get a better picture once the line will be disconnected on both sides.
take a lot of pictures. it will help you put every thing back in place.
