Old 10-09-2012, 06:24 PM   #4
stephe57
Originally Posted by ohhh my View Post
Opened up my engine today to see if I could solve my 2 engine code which comes on about once every 2 weeks. The codes are P0171 and P0174, which says my engine is running lean. I noticed these 2 things not plugged into anything. Where do these 2 ends plug into?
So the one way check valve is connected to your intake manifold. There is a little nipple off the right side of the throttle body on the plastic intake manifold insert and it pushes into that. In the picture, the way your holding the valve is pretty much pointing right too it. Between the TB and that hose clamp, around towards the bottom. As far as the other vacuum line there is a couple different places that can hook up too, but they both are related to secondary air and can cause lean faults. PM me if you have any questions.
stephe57 is offline   Reply With Quote
