Originally Posted by san rensho
Don't use a coat hanger. Get a bicycle brake cable and push the rounded end into the drain, will unclog anything.
And, there are two drains per side on the rear. The one in the foam is easy, but there is another one that is hard to find unless you know where it is. With the top in the service position, theres a 3/4 in by 3 inch piece between the door and the clamshell. Underneath that peice, there is another drain, hard to find.
WOW!
First time I hear about that.
Any chance you can post a pic?
I have a small amount of water coming in on the passenger side. Since both drains are clear ( the two in the foam that are very visible in service mode), I was assuming the top is leaking.
I just got back from the car ( after reading your post ) and I cannot find the extra two holes you are talking about.
Any help will be apriceated.
