Old 09-24-2012, 08:27 AM   #3
seventythree
OK, got it off.
Kenny was right, a little PB Blaster does help. But it's really helpful to pry where 3 locating dowel pin are. With my not so good eyesight, I wasn't seeing those at first. Just apply a tiny bit of penetrating oil to those pins and you should be good.
Now, for my next question:
The flywheel surface is very smooth; it passes the twist test; there seems to be no obvious problems; however, the friction surface is discolored. Is this normal, or does it warrant replacement?
If difficult to answer without visual aid, I'll post pictures later on today.
Regards
seventythree is offline   Reply With Quote
