Old 09-21-2012, 03:52 AM   #2
shadrach74
Originally Posted by davetheviking View Post
what is the rms. I know about the interm. shaft.
if you look at the tarns by its self. you will see a place where the cv joint is bolted on to the trans that is call the output shaft from the trans. this may be a BMW term but that is what I know for now
RMS = Rear Main Seal
IMSB = Intermediate Shaft Bearing.
Mileage? Year? Model? If your getting any noise at the rear of the engine, I would isolate it with a stethoscope. A member recently found the cause of his squealing to be a loose spark plug. However, it could be a number of things...
shadrach74 is offline   Reply With Quote
