Originally Posted by milliemax
Recycle, I had my car serviced on Monday, 9 qts. Stopped for lunch on my way home and noticed the level gage going a little crazy ????? Got home and washed the car to give the oil time to level out and was 3/4 quart low. Added and now All is reading correct. This is my second oil change and once again weird readings until the oil leveled out with time ????? I know that I have not given you the answer but share your concerns. Max
Thanks Millimax. Yes I put almost 9 litres in so u could well be right -the dash guage maybe has to settle down first. If u put in 9 qts and I put in 9 litres(1 litre is slightly less than a quart), I might be okay. Will give it time to settle.
