Originally Posted by Autobot152
i dont recall it ever happening prior to installing the hard top. the hard top has been on for the last couple of months so i have not had a chance to experience it with the soft top up.
Good point, tho! the window rolling down is similar to when you unlatch the front latch prior to retracting the soft top. I will look into the latch. The weird thing is that it is only happening with the driver's side window. When you unlatch the soft top, both windows open slightly.
let me try to understand. the problem is with your driver's side window dropping 1/3 of the way down
and
when you unlatch the soft top, both windows open "slightly"
Slightly as when you open the door?
If this is true, my conclusion would be that the door/window control processor is out to lunch. would remove battery power for couple of minutes and then reconnect the battery. my $0.02
hope you find the bug
