Old 09-18-2012, 07:51 PM   #2
schoir
If it does the same thing whether you pull on the inside or outside door handle, then it's the microswitch inside the door lock assembly.
This is a common problem that has been written up here before. Do a search and you should find all the info you need to replace the assembly. Porsche does not sell the microswitch separately.
Regards, Maurice.
schoir is offline   Reply With Quote
