Originally Posted by sb01box
Does this happen with top up as well as top down? If only with the top up, the micro switch by the rear view mirror (where the top's latch goes) may be at fault and is signalling that you want to put the top down
i dont recall it ever happening prior to installing the hard top. the hard top has been on for the last couple of months so i have not had a chance to experience it with the soft top up.
Good point, tho! the window rolling down is similar to when you unlatch the front latch prior to retracting the soft top. I will look into the latch. The weird thing is that it is only happening with the driver's side window. When you unlatch the soft top, both windows open slightly.
