more clues
O.K. taking this problem further... Now that the top motor is synched and the top light goes off on the dash, things have changed.
Open the passenger door, and things work as they should! Same is true if opening from the inside or outside latch. OPen the door, light goes on, window drops and stays dropped an inch, close door and window bumps up. Only problem is the window regulator drops but you need to give the window glass a little nudge- it needs some lubrication somewhere. May just fix itself if I use it a bit now that it is working.
Drivers door:
OPen from the inside and window drops an inch. Let go of the latch and the window springs up. It doesn't wait for the door to close.
Same thing happens if you try from the outside latch.
