What does the passenger inside door handle do? Does it work normal?
You didn't say whether the inside worked or not..
Curious if it the inside handle does the same, if they both have the same symptoms.
If they both do the same, then its most likely the door mechanism switch as sb01box described..
RMS, IMS, 87.5K
