if i remember correctly, you should be able to activate both fans in the two levels (high and low).
another option is to go to the relay box, and jumper leg 30 to 87 at each relay.
there are 4 relays in total
right side fan low speed
right side fan high speed
left side fan low speed
left side fan high speed
the relays are located just above the fuse box on the driver side kick panel.
you can find more information about it in the Bentley book.
let me know if you need more info and ill shot you a schematic or a pic.
if your fan still doesn't work, it could be the fan resistor (very common).
