Old 09-09-2012, 04:23 PM   #4
SolidWorks Mike
Originally Posted by srad34 View Post
Well,
The weather was good today so I set about synchronising the roof tranmissions. A big thankyou to Solidworks Mike for the hints and tips. I took my time, checked and readjusted before refitting the clamshell. Eventually the roof is lined up, clamshell nice and even so all good, plus every hinge cleaned and greased!
Just one further question, I replaced the roof latch as this was faulty (and the cause of the problem), but I noticed 2 microswitches, one I assume to activate the roof motor, is the second one to drop the windows?
If so this is faulty as they don't drop so for now you have to do it manually.
Any ideas?
If that switch isn't bad, then it may have something to do with 'programming' where the windows are. From my hours and hours of reading posts on here about various stuff, I seem to remember that you need to set where the windows are for them to work correctly.
I would check the switch first and makes sure it's working. You may also want to search for "Windows don't lower when top opens" and see what comes up.
SolidWorks Mike is offline   Reply With Quote
