Thread: AC question
Old 09-07-2012, 08:07 AM   #12
Meir
1999 base
Meir's Avatar
Originally Posted by ferrytrip1 View Post
What great write up - my 02 base ac stopped working last week - it was recharged a few moths ago but seems to be ineffective again. Not the best for summer in Dubai...
When the indy charged mine up last time he looked for leaks but did not spot any - he warned me it may be the evaporator and advised of the cost to do the work.
How did you determine it was the evaporator?
Simon
First, I would like to thank you all for the kind words.
After spending almost a year now, on this forum (and the pelican forum), and seeing the kindness of this community, and the wheeling to help each other, it was a no brainer for me.
I learned so much (and still learning) from the forums members, so I’m happy to be able to pay back.
As for your leak issue.
As the evaporator is probably the hardest component in the A/C system to replace, it is the easiest to diagnose.
First you need to charge the A/C system with AC dye. This is a special fluid that glows under black light.
Look here:
quick automotive a/c system leak detection using uv dye. - YouTube
AC dye works. Here's how to use it right. - YouTube
You will need these:
Amazon.com: UV Protecting Adjustable Safety Glasses Yellow Tint,7821: Health & Personal Care
Ledwholesalers 400 Nm Uv Ultra Violet Blacklight Flashlight 3 Aaa,7301uv400 - Amazon.com
As you probably know, when you run the A/C, and the car is not moving, you will have a puddle of water under the car. This is the moisture in the air, condensing on the evaporator and accumulating on the bottom of the air box. If the evaporator is leaking, the AC dye you put in the system will mix with the water, and you will have a very nice glowing puddle under your car.
In my case it was so obvious, that I didn’t even needed the black light to see the dye, the water came out greenish.
Looks very cool tough with the flash light and glasses, especially if you are an 80’s fan.
If the leak is not coming from the evaporator, the dye will help you locate where it’s leaking from.
Just follow the lines of the system.
good luck.
