Originally Posted by mikehkang
You can use Durametric to turn it on?
What model year is your Boxster and which version of Durametric did you use?
I have 2001 base.
I have been meaning to do this for a long time.
Thank you.
Mike,
I have Durametric v6. I have a MY01. worked perfect. I used 2 dash switches rather than the 4 stalk setup. I got everything from Sunset in Oregon. Follow the DIY to the letter & you will get it right, it took me about 2 hours because I soldered the wires & heat shrunk them into a harness. I hope this helps.
