Old 09-04-2012, 04:11 PM   #13
Jittsl
SPB racer
Originally Posted by Boxster586 View Post
I had zero issue installing a set of TopSpeed bypass pipes last weekend. In my experience, I had to insert the tail end of the pipe into the muffler and and then align the front.
By the way, there is a video by another member regarding the installation and how he had to have a muffler shop cut two tack welded bolts in order to install. I found this to be not the case. The nuts were tack welded but the bolts still turned. All you need is a simple socket set and a long socket extension to reach two bolts.
Im glad you had no issue.
Yours however must be different from mine. Mine have no adjustment at the front. There is a welded flange that that bolts up to the rear of the headers and that's it. Likewise mine have no tacked in nuts.
Jittsl is offline   Reply With Quote
