Old 08-30-2012, 02:20 AM   #127
politby
politby's Avatar
Originally Posted by BestGear View Post
Yes, I used the connects2 cage as the bezel has clips that need to fit to the cage and on my Kenwood it would not fit properly as the cut outs were not there.
You just need to juggle (on the bench) the side mounting clips so that you get the distance correct - ie the distance from front of head unit to flush with bezel.
Its easy when you see it on the bench, rather than trying to describe it.
David
Got it. Final question - where did you take switched power for the head unit, and how did you connect the parking brake/reverse leads?
politby is offline   Reply With Quote
