Old 08-30-2012, 02:00 AM   #126
BestGear
Originally Posted by politby View Post
So did you use the cage that came with the Connects2 kit, or the one that came with the head unit?
Yes, I used the connects2 cage as the bezel has clips that need to fit to the cage and on my Kenwood it would not fit properly as the cut outs were not there.
You just need to juggle (on the bench) the side mounting clips so that you get the distance correct - ie the distance from front of head unit to flush with bezel.
Its easy when you see it on the bench, rather than trying to describe it.
David
BestGear is offline   Reply With Quote
