Old 08-29-2012, 06:23 AM   #1
jb92563
jb92563's Avatar
I had the same problem in my 2001 Boxter S.
Then I noticed the puddle under the car forming as I poured.
Turns out that when I pulled back the left side wheel well plastic liner to expose the washer fluid bottle, the plastic pickup tube had become detached and drained as I filled the washer fluid reservoir.
Solution was to reconnect the hose and use a hose clamp to prevent a recurrence.
Check for a puddle forming as you fill, if so, check the washer bottle connections behind the left front wheel well liner on the bulkhead side.
