I will venture to say that its both camber and toe. The stock negative camber alignment will wear the inside 1/3 of the tires more than the outside 1/3 and then adding toe just exacerbates the wear.
Yes, you can go to a zero camber and zero toe alignment but cornering performance will suffer.
