			Well, there are two ways to open the hood.
Using the remote button, or the hood switch inside the car.
Could be that one of the two is broken, and create contact on movement.
Try to narrow the problem by eliminating one of the two.
I would start with driving the car without the remot ( remov the battery from the remote and drive the car using the key only).
If problem disappear, you will have to fix/replace you remote.
If problem continues, move to the next step and disconnect the switch inside the car.
Good luck.
