Thread: Top Install $
Old 07-30-2012, 06:52 PM   #15
schoir
Originally Posted by brian325is View Post
I am half way through the install. ie the old top is off. Not an easy job.
I had to order a couple of parts that were damaged from Porsche. If you read the install instructions online they recommend you pre buy because it is highly likely damaged during removal. Not expensive. The sliders were about $15 each x 2.
I decided to do it myself as the logistics of getting it done in Scarboro ( i am in Mississauga ) were too complicated.
The top quality looks excellent but I cannot comment on the fit yet
Brian:
If you take your time, don't cut any corners and follow the DIY instructions posted on Mike Focke's website, you can get a perfect result.
It's tempting to expedite matters because it's such a lengthy process, but if you stick to it you'll be very pleased with the end result.
Regards, Maurice.
schoir is offline   Reply With Quote
