Be sure to check the dual mass flywheel while you're doing the clutch. It is likely worn out after 90K miles.
And while you have the drive shafts off to replace the CV joints and boots, check the spider gear in the transaxle. If any of the previous owners were doing burnouts, it is likely pitted and worn.
