Old 07-25-2012, 02:03 PM   #11
986_inquiry
2006 987
986_inquiry's Avatar
Originally Posted by seningen View Post
We have a Cayman at the shop with a similar issue. Overheated it which has led to coolant in the combustion chamber. Just got here so I don't have details.
However this car would still run.
There are specifics I would get from your mechanic, like what exactly does he mean when the engine is blown?
debris in oil?
any CEL codes?
oil in coolant?
coolant in the oil?
Did the water pump fail?
Has he boroscoped the cylinders? Is there coolant in the cylinders?
good luck with the car,
Mike
From mechanic:
overheated engine so bad it won't run that sums it up. it's hits on a cylinder here in there just won't run
986_inquiry is offline   Reply With Quote
