Old 07-18-2012, 01:14 PM   #11
jb92563
jb92563's Avatar
Originally Posted by Crono0001 View Post
On the videos, it seems like the unit fits in pretty flush, save that opening up top. Are you sure we even need an install kit?
When I put the plastic bezel on that the unit comes with there is maybe 1/16" on either side which is visually nothing.
However the top and potentially bottom will need something to cover it.
Thats where my 1/8" thick aluminum aircraft style surround will go and any plastic
will mount on that face.
The stereo will sit on an aluminum shelf inside, attached to the front plate.
The front Plate will have some counter sunk depressions for screws and the screws will be hidden by the plastic glued or velcro'd on top.
I departed from the typical Auto tray idea since there does not seem to be any good attach points.
However the upper Din Slot holes are intact and will make a good attach point and at the bottom the face can key in with the existing plastic and metal there without screws.
I thought I read about another install that used a $25 DD install kit for another car type successfully. Need to do some googling.
