Old 07-15-2012, 12:05 AM   #28
jb92563
jb92563's Avatar
Sorry I have not posted more plus a video I took but I got busy with other stuff.
I took a few minutes this morning and tested all the wires in the radio Harness and discovered where they need to go.
Everything is working and I discovered that since I had the Amp and 6 CD changer in the frunk I had to wire the speaker wires to the yellow connector block in the car and it will not work without my Equalizer plugged in.
I will try without the CD Changer conected, only the Amp and see if that works.
The good news is that I think I will be able to simply push the connected Equalizer panel into the tray slot and with slight modification push the tray in the slot with the EQ panel behind it.
Next thing now that the wiring is sorted out, is to make a tray or bracket to hold the radio securely in place.
I'll see about posting my progress and video from Friday in the morning.
