Old 07-10-2012, 08:33 PM   #20
schoir
Originally Posted by huskeydad View Post
All the information helps but my idiot light for the hand break does not light on the dash when it is engaged. As soon as the vehicle is started it goes out without the parking break released. Already checked the fuses and they are OK. In all the posts I did not see if the light does not work, what does it mean. The convertible relay or the lock sensor switch? Failed the first time ever a few days ago.
Since the idiot light is on and then goes out when you start the car, even with the parking brake on, then the culprit is the microswitch at the base of the hand brake.
Sometimes you can get the microswitch to come back to life by vigorously pulling up on the handbrake, then releasing it suddenly, etc... for a few cycles. You might also get away with shooting some heavy duty compressed air at the microswitch, otherwise you will have to replace it.
Your convertible top will not operate without that idiot light going on, unless you get a SmartTop double relay or do the hack that allows you to bypass having to have the parking brake engaged.
Regards, Maurice.
schoir is offline   Reply With Quote
