The water that gets under the front hood will either dry on its own or drip down into the area beneath the battery and go out the front drains (which are located on both sides of the battery). So, nothting to worry about (unless your front drains are clogged which is why you should check them every 6 months or so). While you're at it, you might was well check the rear drains too.
