Check the tire sidewalls for excessive tire roll. Many tires have little small triangles molded into the tire around the outside edge of the tire. The tire wear boundary shouldn't go past the tip of the little triangles. If this is happening, then go up a few pounds in air pressure to try and stiffen up the sidewall and see if that helps.
I'll try and post a picture later today for an example.
