Old 06-13-2012, 11:53 AM   #14
2000boxster986
2000boxster986's Avatar
To JFP in PA: I too am installing my IMS bearing via the Pelican article and have the sprocket locked with three set screws. Two tensioners are removed as well per the Pelican article. My IMS is also cocked a bit in the case hole.
Now I'm concerned after reading your response below... I currently have a new (pelican) bearing stuck half way in the IMS and hopefully will be pulling it back out when LN sends a hexagon shaft tool to fit the new bearing shaft (ordered it yesterday)... Once/if I get the bearing out is it possible to put tensioners back in (or not) and rotate to TDC? I don't think I want any movement here but need to ask. If this isn't possible then I'm going to make a lock that fits to the engine case and one or two of the bolts on the flywheel flange.
Too bad the LN and Pelican procedures are so different. Seems it can really get us hobbyist in hot water. Appreciate any info you wish to share on my issue. It appears others have been in similar positions. Thank you, Rgs, John mickymingjh@gmail.com
2000boxster986 is offline   Reply With Quote
