Old 05-16-2012, 11:07 PM   #9
schoir
Originally Posted by CVstarBoxster View Post
any clues on this issue? i'm having a similar issue. My top won't close
We need more information to diagnose this properly.
Have you set the emergency brake AND has the idiot light on the dashboard lit up, showing that the emergency brake is on?
If you have answered yes to the two above questions, then the problem lies in one of two fuses, a dead spot on the armature of the electric motor, a bad convertible top double relay or corrosion on the spades of the relay.
Can you supply some more details. Year of your Boxster, is this first time that this has happened...do you hear any noises or see the lights dim when you press the button?...
Regards, Maurice.
schoir is offline   Reply With Quote
